# Horizon network device configuration
#source "../hobot-drivers/ethernet/hobot_fpga"
config RTC_HOBOT
	bool "Hobot RTC devices"
	default y
	help
	  Hobot Rtc.
config HOBOT_RTC_SET
	bool "Hobot ACore RTC Set function"
	depends on RTC_HOBOT
	default n
	help
	  Allow ACore configure the RTC located in MCU Domain
config RTC_DRV_YSN8130
	tristate "Hobot YSN8130e"
	default m
	help
	  If you say yes here you will get support for the YSN8130.
	  Optional device tree on the I2C RTC node (rechargeable backup cell):
	    drobot,backup-charge-enable = <1>;
	    drobot,bfvsel = <0..3>;
	  When backup-charge-enable is non-zero, CHGEN and BFVSEL are written to
	  register 0x1F per datasheet Table 18 (BFVSEL=3 is unlimited charging).
	  This driver can also be built as a module. If so the module
	  will be called rtc-ysn8130.
